• For testing only, data may change, data here will be wiped out. Live conversations should happen in main site at https://fordsix.com
Hello From Atlanta GA
#1
Hello!
I recently purchased a 62 Comet for my daughter.
It is sort of a H.S. Graduation gift that she gets to help build.
It has a running 170 with Holley 1909.
I was told the engine and tran had been rebuilt.
I have worked on classics in the past but mainly FE motors and 350's
This little 6 is a new thing to me
Hoping to make this a father/daughter project that she can take to college with her at the end of this summer.
Looking forward to gleaning and hopefully providing some insight
wsa111
Moderator
Staff member
#2
Welcome aboard from the big A.
I would install new seat belts for safety reasons. You will have to reinforce the B pillar for the shoulder belt.
Install new plugs & i would advise a pertronix 1 to replace the points. You will need a full 12V for the pertronix.
Install a relay to get a reliable 12V source to the dist..
Check the tech section of the forum if in doubt in relay wiring. Bill
Moderator
Staff member
#3
Welcome to the Ford a Six forums Chapa71, sounds like a great plan for your daughters 62 Comet! Good luck on the 62 build and having been able to do the same with my father you and her will also remember the time you spent togeather on the Comet. :thumbup: :nod:
